It is currently Sun Aug 24, 2025 11:07 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Sat May 11, 2013 4:55 pm
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
I have found standard diagonal cutters like those an electrician use work well for cutting standard and stainless. Electricians linesman cutters work even better with stainless. Yes they don't cut flush and you have to do a little more work but it's not that big a deal...Mike
PostPosted: Sat May 11, 2013 11:43 pm
Be careful with using an abrasive disc to flush cut SS frets if it's installed... I charred the maple binding to hell when doing it that way.
Geeze, not to be mean or anything, but you deserved that one....
PostPosted: Sun May 12, 2013 12:14 am
Last Name: Shaw
City: Phila
State: PA
Yeah there is a so called luthier tools seller on ebay that sells these just for this reason. I laugh every time I run across his auctions and feel sorry for the suckers that got caught.
PostPosted: Sun May 12, 2013 12:24 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
For the record I was trying to grind the frets flush with a grinding wheel, because at the time (with a very limited shop) I didn't have the tool to grind SS frets. The frets got so hot that it burned the wood it was on.
Typhoon Guitars
PostPosted: Sun May 12, 2013 10:09 am
As I said, you deserved that one.... All you need is the same fine file you use with every other fretwire; they don't need to be attacked with a grinder.
PostPosted: Sun May 12, 2013 11:29 am
I would think that you also changed the color of the SS and locally altered its temper...don't ask me how I know that....
PostPosted: Sun May 12, 2013 11:33 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I eventually changed it to nickel fret after not being satisfied with the job... worked better after that.
Typhoon Guitars
Users browsing this forum: dofthesea, phavriluk and 24 guests
